u4gm Path of Exile Gudie: Crit CoC Discharge of Misery Assassin - Printable Version +- Motobuys Forum (https://forum.motobuys.com) +-- Forum: About this Forum (https://forum.motobuys.com/forumdisplay.php?fid=9) +--- Forum: Suggestions and Feedback (https://forum.motobuys.com/forumdisplay.php?fid=24) +--- Thread: u4gm Path of Exile Gudie: Crit CoC Discharge of Misery Assassin (/showthread.php?tid=352898) |
u4gm Path of Exile Gudie: Crit CoC Discharge of Misery Assassin - 1fuhd - 07-16-2025 The Crit CoC Discharge of Misery Assassin build in Path of Exile represents a powerful and technically intricate character setup that leverages critical strikes and the Cast on Critical (CoC) mechanic to unleash overwhelming elemental damage. Centered around the Assassin ascendancy, this build excels at rapidly triggering the Discharge of Misery skill, a transfigured version of Discharge that boasts no cooldown but a larger area of effect and reduced base damage, balancing sustained area damage with fast interaction PoE 1 Currency. This guide will explore its mechanics, gear, gem setup, defenses, and playstyle to highlight why it stands out in the current PoE meta. At the core of this build is the ambitious goal to scale critical strike chance and multiplier to 100%, allowing the Discharge of Misery to be triggered constantly with devastating effects. The use of the Awakened Cast on Critical Support gem, typically at level 10, combined with critical strike multi-boosting jewels and Assassin notable nodes like Unstable Infusion and Deadly Infusion, dramatically increases both crit chance and damage. Power and Endurance charges are stacked aggressively to further improve damage output and survivability, while a high Cast Rate ensures rapid procs, achieving around 10 casts per second according to recent benchmarks. Gear selection focuses on maximizing critical stats, elemental damage, and charge generation. The build often relies on specialized rings and boots that grant a very high chance to gain maximum Power Charges on critical strikes, as well as helmets with abilities to increase charges or boost cast speed. The unique Wraithlord helmet with +2 to Raise Spectre is popular, as it synergizes well by providing minions that add additional damage layers. Defensive stats like energy shield and elemental resistances are vital, given the build’s relatively low Life pool, with investments in flasks, shaper’s touch gloves, and jewels completing the balance between offense and defense. The gem setup strategically combines Discharge of Misery with a variety of support gems to maximize area damage and critical hits, such as Empower, Inspiration, and Faster Casting. Cast on Critical Strike setups include Power Charge on Critical, and multiple levels of Awakened Cast on Crit to achieve the required cast rate breakpoint. Auxiliary skills like Cyclone offer mobility and secondary damage; Immortal Call linked with Cast when Damage Taken provides crucial survivability. Buffs from auras like Wrath and Zealotry amplify elemental and critical damage, completing the build’s powerful synergy. In gameplay, the Crit CoC Discharge of Misery Assassin excels in fast mapping and boss encounters. Players typically cyclone around packs of monsters, applying ignites, chills, and shocks while Discharge periodically detonates maximum charges of Power, Frenzy, and Endurance, resulting in massive area damage. The build’s speed and damage make it capable of handling endgame content effectively, although its fragile life pool demands careful positioning and usage of defensive layers. Coordination between buffs, charge uptime, and intelligent movement is key to maximizing performance PoE buy Currency. In conclusion, the Crit CoC Discharge of Misery Assassin is a high-skill, high-reward Path of Exile build that offers incredible speed and damage potential through critical strikes and charge management. Its distinct use of the Discharge of Misery gem without cooldown revolutionizes the traditional Discharge playstyle, requiring players to master charge generation and cast timing. When equipped and played correctly, it stands as one of the most potent caster-based assassins in the current meta, perfectly blending burst damage with elegant, fluid combat mechanics. |
