CGSLabs Infrastructure Design Suite 2026.0 For AutoCADBricsCAD Multilingual (x64) - Printable Version
+--- Thread: CGSLabs Infrastructure Design Suite 2026.0 For AutoCADBricsCAD Multilingual (x64) (/showthread.php?tid=595410)
CGSLabs Infrastructure Design Suite 2026.0 For AutoCADBricsCAD Multilingual (x64) - BestSoftCrack - 09-08-2025
[Image: ff4312775e1b3c78aac30e690ec78dab.png]
Free Download CGSLabs Infrastructure Design Suite 2026.0 For AutoCAD/BricsCAD (x64) Multilingual Fast Links | 1.4 GB
We are developing innovative software solutions in the field of planning, construction, management and maintenance of buildings and advanced weather information systems to support the maintenance of transport infrastructure. We contribute to greater transparency, quality and cost-effectiveness of construction projects and support sustainable decisions.
With information highways, we connect people and data to open systems. We build solid bridges between the design, construction, management and maintenance of our built environment, and help maintain a clean and healthy natural environment. We are introducing breakthrough technologies that are changing the way we work and think. We listen to the wishes of our users and help them, and the borders of our homeland are not an obstacle to our global operations.
BIM Roadway Design
Plateia is a professional, BIM-ready, 3D road design and reconstruction software solution. Using its flexible, dynamic data model, it supports BIM workflows and processes, and IFC standardized data format.
Intuitive user interface
Carefully designed UI and workflows are consistent with the road design engineering practice. This makes Plateia fast-to-learn and easy-to-use.
From preliminary to detailed design
It provides the commands and tools to support the entire design process. From preliminary to detailed design, from the initial input of survey data to complex 3D road models with analysis tools, to documentation and publishing features.
BIM railway design Solution
Ferrovia is a professional, BIM ready solution for railway design and rail track analysis compliant with country-specific guidelines. Using its flexible, dynamic data model, it supports BIM workflows and processes, and IFC standardized data format.
Integrated railway design and maintenance
Ferrovia provides tools for alignment and profile design, detailed cross section design and editing, applied cant, turnouts and rail connections. Alignment and profile regression analysis tools provide users with options for comprehensive rail track realignment and tamping machine guidance capabilities.
Carefully designed UI and workflows are consistent with the railway design engineering practice. This makes Ferrovia fast-to-learn..
BIM Channel/River engineering design
Aquaterra is a professional software for channel and river engineering design. It integrates MIKE FLOOD and HEC-RAS hydraulic calculations with flood protection design, torrent and landslide control, and irrigation systems design. Using its flexible, dynamic data model, it supports BIM workflows and processes, and IFC standardized data format.
Carefully designed UI and workflows are consistent with the engineering practices. This makes Aquaterra surprisingly fast-to-learn and easy-to-use.
Aquaterra facilitates design in all stages of the project, from conceptual studies to detailed design. From the river axis, longitudinal and cross-sections data, user can quickly build a 3D Solid model of river bed and river bank, calculate quantities, and prepare printed documentation.
Features
DIGITAL TERRAIN MODEL
SITE DESIGN
Roadway design
Road reconstruction / rehabilitation
Implemeted national road design standards
AUTOSIGN - 3D/BIM Traffic signs & Road Markings design
AUTOPATH - Swept path analysis and vehicle turning simulation software
Support for BIM and IFC
Infracloud - Plateia extension
System Requiremens:
Support Bricscad:20-23
Support Autocad:2018-2026
https://cgs-labs.com
d98w5.CGSLabs.Infrastructure.Design.Suite.2026.0.For.AutoCADBricsCAD.x64.Multilingual.rar.html
