Motobuys Forum General New Member Introductions v
1 2 3 4 5 … 22 Next »
Hello Guys and Gals, Just received my Traimaster Sorento 150 2 days ago.
dsvinas
08-17-2024, 07:06 PM
I took it out for a spin for the first time today…it is going to need some tweaking. Rear brake has no effect, the sight glass looked full of brake fluid, hmm….also searching for engine oil info as to: do I need to top off the engine oil before I really make it my work horse or should have I done that before I took the less than a mile test?
uiseimpeccable
11-20-2024, 08:06 AM
1. Rear Brake Issue: The rear brake might need bleeding to remove air from the lines, even if the sight glass shows full fluid. Check the brake pads too, as they might be worn.
2. Engine Oil: It's a good idea to check and top off the engine oil before using the bike regularly, even after a short ride. If it's low, topping it off will prevent engine damage.
Make sure to consult your bike's owner manual for specific maintenance details.
drift hunters
