01-24-2025, 06:59 PM
Washing one’s face at night is a therapeutic process. While what time you should wash your face at night may vary according to your routine, there isn’t much that goes into it and a set process should be followed. Benefits of washing face with cold water before bed
Step 1: Gather Your Supplies
Collect all the necessary supplies, including a gentle cleanser suitable for your skin type, a soft towel, and any additional products like toner, moisturizer, and specific treatments.
Step 2: Remove Makeup
Before cleansing, use a makeup remover or micellar water to thoroughly remove any makeup. This ensures that your cleanser can focus on cleaning your skin, rather than battling through layers of makeup.
Step 3: Wet Your Face
Splash lukewarm water on your face. Avoid hot water. Washing face with cold water before bed is equally bad, since it won’t soften the surface. Lukewarm water helps open up your pores and allows the cleanser to work more effectively.
Step 4: Apply Cleanser
Take a small amount of your cleanser. Gently massage it onto your face. Pay special attention to areas prone to oiliness or where makeup was applied. Be sure to be gentle and avoid using excessive force or harsh scrubbing, especially if you have sensitive skin.
Step 5: Rinse Thoroughly
Rinse your face thoroughly. Preferably with lukewarm water. Incomplete rinsing can leave residues that may irritate the skin. Pat your face dry with a clean and soft towel, and leave your skin slightly damp for better absorption of subsequent products.
Step 6: Apply Products
If you use toner, apply it using a cotton pad. Then use a suitable moisturizer to keep your skin hydrated. Choose a product that complements your skin type—whether it's a lightweight formula for oily skin or a richer one for dry skin.
Step 7: Specific Treatments (Optional)
If you use specific treatments like serums or spot treatments, apply them after your moisturizer. These products can target specific concerns such as acne, hyperpigmentation, or fine lines. You can also end with a small amount of eye cream, or lip balm, as per your requirements.
