« Previous 1 … 1756 1757 1758 1759 1760 … 3582 Next »
Blackmagic Design DaVinci Resolve Studio 20.1 Linux
Threads: 1,783
08-25-2025, 10:04 AM
[Image: fe74400f04cf46bf523a51df44960e86.webp]
Free Download Blackmagic Design DaVinci Resolve Studio 20.1 Linux | 8.6 Gb
Languages Supported: English, Português, Français, Español, 中文, 日本語, Русский
Blackmagic Designhas announcedDaVinci Resolve Studio 20.1. This software update adds support for Apple Iimmersive workflows, Apple Vision Pro monitoring and Apple Spatial Audio Format for macOS users.
In addition, there is support for AI Magic Mask 2 in Fusion and improved MultiText character and paragraph level styling. This update also adds the option to process clip compositions in your timeline resolution, improved safe area controls with new custom guides, rulers and snapping tools on the cut and edit page. Support for 32-bit floating point recording on cut, edit and Fairlight timelines has also been added.
Owner:Blackmagic Design
Product Name:Davinci Resolve Studio
Version:20.1
Supported Architectures:x64
Website Home Page :www.blackmagicdesign.com
Languages Supported:multilanguage
System Requirements:Linux *
What's new in DaVinci Resolve Studio 20.1
Key Features
- Apple Vision Pro spatial and immersive video workflows in macOS.
- Direct monitoring of immersive content in Apple Vision Pro.
- Support for Apple Spatial Audio Format.
Cut and Edit Page
- Improved easing behavior for multiple keyframes.
- More consistent easing for curves, keyframes and inspector controls.
- Improved curve editor for active curves, ease, locked parameters.
- Ability to adjust curves from the timeline keyframes and curves tray.
- Keyframes are now displayed beyond clip edit points.
- Ability to set a shortcut to switch between curve and keyframe views.
- Curves option to disable auto zoom graph height for custom zoom.
- Support for built in MultiText character level styling.
- Support for MultiText indent, align and paragraph level styling.
- Ability to import CSV files as column-aligned MultiText text boxes.
- Additional smart reframe mode to affect pan only, tilt only or both.
- Support for custom guides and snapping in the timeline viewer.
- Ability to toggle extents for selected safe area overlays.
- Ability to create subclip from edit timeline in out range.
- Support for find in media pool for USD based geometry clips.
- Options to sync media pool audio using in, out and marker.
- Ability to sync audio for stereoscopic 3D videos.
- Menu action to move playhead to mouse pointer using the C key.
- Menu actions for full extent, detailed and custom zoom for timeline.
- Timeline tab action to load to source viewer.
- Configurable actions to explicitly enable or disable clip.
- Audio and video only insert controls in the source viewer.
- Improved right to left language handling in transcriptions.
- Ability to view transcriptions for clips on the source timeline.
Fusion Page
- Support for new immersive option in the viewer 360 Views menu.
- Support for new immersive patcher tool.
- Support for Magic Mask v2 in Fusion.
- Support for caching deep composites to disk.
- Option to downscale clip compositions to timeline resolution.
- Improved DoD and RoI support for deep image compositing tools.
- Improvements for USD Renderer for overscan.
- Edit individual tool controls from the inspector context menu.
- Improved shape duplicate tool with style, jitter and aligned rotations.
- Support for swizzler to create alpha only multi layer outputs.
- Support for swizzler background channels.
- Support for regular expression based selection in Cryptomatte.
Color Page
- Improved color viewer safe area display selection.
- Ability to switch timeline resolution on the fly from the color viewer.
- Improved cache retention for copied versions and timelines.
- Improved magic mask retention for copied versions and timelines.
- DCTL Support for ACES 2.0 Core.
Resolve FX
- New ColorTone Diffuser emulates light based lens filters.
- Natural and strong split tone modes in Film Look Creator.
- New Split Tone with additional controls.
- Separate RGB sliders and shimmer controls in light rays.
- Secondary glow ability in glow.
- New atmosphere controls in light rays and glow.
- Ability to regrain skin smoothening areas in face refinement.
Fairlight Page
- Support for half speed timeline playback.
- Action to enable focus mode using the W key.
- Ability to record in 32-bit floating point.
- Audio waveforms are now accurate when recording.
- Clip context menu action to regenerate waveform profiles.
- Faster Audio Assistant analysis with short clips improvements.
- Audio Assistant option to view the full UI of underlying effects.
- Dialogue matcher ambience controls and improved wet dry matches.
- Support for deleting busses from track headers and index.
- Shift option command for fine mouse based scrubbing zoomed out.
- Shift and command click to add to selection in mixer.
Codec and IO
- Support for Blackmagic RAW 5.0 SDK.
- Faster decodes for URSA Cine 12K LF and URSA Cine 17K 65 clips.
- Support for decoding and encoding webp images.
- 12-bit support and custom quality controls for DNx.
- Support for encoding H.264 and H.265 in MXF Op1A clips.
- Support for decoding Samsung APV clips.
- Improved native Windows H.264 and H.265 bit rate controls.
- New deliver preset for Tencent video uploads.
General
- Improved layouts for small, dual screen and vertical video views.
- Improved per-system bin layout retention for multi-user projects.
- Use shift space to display the effects search dialog in all pages.
- Ability to search for effects in both English and application language.
- Clone tool support for xxhash64 checksums.
- DRT timeline exports now include Fusion media references.
- Viewers now reflect updates to still images by other applications.
- Concurrent viewer overlays for DeckLink and remote monitoring.
- Scripting API support for voice isolation for audio clips and tracks.
- Support for Electron 36.3.2 for workflow integrations.
- New Javascript promises API for asynchronous workflow operations.
- Support for audio only TS growing files.
- General performance and stability improvements.
Davinci Resolve Studiois a professionally focused video editor from the Australian company Blackmagic Design. The program has a wealth of features and is a great choice, both for experts and aspiring creators alike. Much of its marketing material shows people with professional workstations hooked up to it. If you're used to working with these multi-buttoned behemoths, Davinci Resolve Studio may be the video editor for you. Blackmagic makes film industry hardware, as well as software, and Davinci Resolve Studio is an excellent tool for production-quality video work.
Davinci Resolve 20 Is Incredible
Talking about Davinci Resolve 20 and some of my favourite video editing features coming out of it! Sorry if this video is all over the place, I was really excited haha
Blackmagic Designcreates the world's most advanced video editing products, video converters, routers, color correctors, film restoration software and waveform monitors for the feature film, post production and broadcast industries. Blackmagic Design's DeckLink, Mini Converters, Videohub routers and UltraScope waveform monitoring products revolutionize the television industry by making advanced post production tools affordable to thousands of creative professionals. Blackmagic Design's DaVinci Emmy award winning color correction products continue to dominate and lead the industry with ground breaking innovations including stereoscopic 3D and 4K workflows. Blackmagic Design has offices in the USA, UK, Japan, Singapore and Australia.
[Image: 79276266cb35a1e2e36efc5cccec10ac.webp]
i3ydm.Blackmagic-Design-DaVinci-Resolve-Studio-20-1-Linux.part1.rar.html
i3ydm.Blackmagic-Design-DaVinci-Resolve-Studio-20-1-Linux.part2.rar.html
i3ydm.Blackmagic-Design-DaVinci-Resolve-Studio-20-1-Linux.part3.rar.html
