« Previous 1 … 756 757 758 759 760 … 2857 Next »
Systweak Data Recovery 2.1.1.265 Multilingual Portable
Senior Member
Threads: 652
08-26-2025, 01:53 PM
[Image: 74d883414a98e4a608fec62b1f98fc69.webp]
Free Download Systweak Data Recovery 2.1.1.265 Multilingual Portable Fast Links | 41.29 MB
Recover Deleted & Lost Data Easily from Various Devices in 1-Click. Retrieve data from HDD, USB Stick, SD Cards, Recycle Bin & other external devices. Restore data lost due to formatting, virus attack, human error, hardware failure, etc. Preview files before recovering data to know which files to recover. Supports recovery from NTFS, exFAT, FAT, and other file structures.
Best Data Recovery Software for Windows
Losing any type of data, be it photos, documents, archives, audio and video files, or any other file type, is frustrating. Fortunately, using Systweak Data Recovery software, you can restore any lost file types from HDD, SD card, USB device, SSD, or Recycle Bin.
Hard Disk Drive
Data loss is inevitable. It can happen due to hard disk failure, mistakenly deleting files, malware attacks, or any other factor that is not under your control. The essential thing is to know how to find deleted files on your hard drive. This is where Systweak Data Recovery comes to play. The tool helps recover deleted images, music, documents, archives, and files from a hard drive on the Windows operating system. Also, it shows a preview of contents for deleted or lost files, allowing you to recover what you need.
Computer Desktop
Most of us save data on the computer desktop for easy access. However, when the low storage space message is encountered, this data is the first to be sacrificed. If you, like others, have accidentally deleted your photographs, movies, excel, word, and audio files from your computer's desktop, use Systweak Data Recovery. The program efficiently recovers data types like JPG, BMG, GIF, PNG, MP4, AVI, WAV, Docx, XLSX, and other file formats from your Windows PC. Also, to restore the maximum amount of deleted data, the software searches and reads through each sector on the disk.
Recycle Bin
Using the Delete key, when a file is deleted from the PC, it is temporarily transferred to the Recycle Bin. However, once the Recycle Bin is emptied, recovering data manually becomes impossible. Luckily, using Systweak Data Recovery, the top-notch recovery tool for Windows, you can retrieve data even after the Recycle Bin is cleaned. This tool scans the hard disk for deleted files and facilitates the recovery of those files. However, recovery can be tough if you have used the system after deleting the files. Therefore, avoid using the PC to recover data once you realize it is gone.
USB Drive
If you are stuck in a situation where you have lost precious memories saved on a USB device, and require assistance retrieving them, look no further than Systweak Data Recovery. It is a reliable and trustworthy file recovery program that helps recover various file types, such as documents, images, movies, music, and more, from USB sticks that have been formatted, corrupted, encrypted, damaged, and more. Users trust the tool as it supports the recovery of different file types and formats.
SD Card
If you encounter a situation where your SD card becomes inaccessible, corrupts, or displays alerts such as "Micro SD card is not formatted, and you can't access anything saved on it," what steps would you take? In such instances, the best way to recover deleted photos, music, and other file types is through a reliable SD card recovery tool. Systweak Data Recovery is that powerful SD card recovery software that handles crucial data loss scenarios & helps retrieve lost or deleted data from your Windows PC.
External Hard Disk
When the external hard disk that you use to keep data safe is formatted, or you have accidentally deleted data from it, feeling frustrated is natural. But there's nothing to worry about, as only the logical access to the data is removed, but the files are still there. Using Systweak Data Recovery, the professional data recovery tool, you can easily restore these lost/ deleted files. The tool repairs the logical links and makes the deleted files and folders accessible.
Solid State Drive (SSD)
As SSD drives are commonly used, people are experiencing data loss and looking for ways to regain lost data. However, since SSDs are different from hard drives, a standard recovery tool fails to perform the task. This is when Systweak Data Recovery, the SSD data recovery, can be used. If the TRIM command is disabled on your SSD, you can restore music, video documents, and other erased data from various SSD using this powerful recovery program.
Quickly Restore Data Lost Due to Any Data Loss Scenario
Realizing that you have accidentally deleted important documents, photos, videos, or audio files can be devastating. However, with the trusted software Systweak Data Recovery, you can restore various lost or deleted file format types.
Deleted File Recovery
Without wasting time, quickly preview and recover deleted files, photos, videos, mp3s, documents, archives, & more from various storage devices on Windows PC.
Recovery from Formatted Drive
If you have experienced data loss due to a formatted partition or accidentally formatting a drive, don't worry. With Systweak Data Recovery, recover your lost data.
External Device Recovery
Effortlessly recover deleted data from a wide range of devices, including flash drives, USB drives, SD cards, memory cards, external HDDs, and other compatible devices.
Emergency Data Recovery
With Systweak Data Recovery, you can effortlessly recover files lost due to virus attacks, unexpected system crashes, power failures, accidental deletion, and OS reinstallation.
Operating System: Windows 11/10/8.1/8/7 SP1
https://www.systweakdatarecovery.com/
e24x5.Systweak.Data.Recovery.2.1.1.265.Multilingual.Portable.rar.html
