« Previous 1 … 7 8 9 10 11 … 3624 Next »
PC Cleaning Utility Pro 3.8.7 Premium Multilingual Portable
9 hours ago
[Image: 2ee5ad0db09f1ea0691c876ad0e68b42.webp]
Free Download PC Cleaning Utility Pro 3.8.7 Premium Multilingual Portable Fast Links | 5.8 Mb
Use PC Cleaning Utility to clean your PC of files that are clogging and crowding your hard drive. PC Cleaning Utility is a system cleaner that makes cleaning your computer a safe and simple process. Over time a computer becomes full of files that eventually clog the hard drive. PC Cleaning Utility cleans files that could be causing your computer to perform at a substandard level. By cleaning up problematic files, PC Cleaning Utility will help prevent system crashes and freezes.
With PC Cleaning Utility you can choose which areas on your computer to scan and clean. Choose from virtual devices, libraries, installations strings, junk files, temporary files, system software, history and start menu, and more. PC Cleaning Utility is easy to install and only takes a few minutes. There is no long complicated process because PC Cleaning Utility's settings ensure a smooth, trouble-free installation process. Save time by installing PC Cleaning Utility now so you don't have to spend time later attempting to fix complicated system issues.
Clean
PC Cleaning Utility cleans and realigns files that could be slowing down your computer and causing it to perform at a substandard level.
Reduce Clutter
File clutter can take up much needed space on a user's computer causing it to function sluggishly. Use PC Cleaning Utility to reduce clutter and free up hard drive space.
Manage PC Health
By cleaning up problematic files, PC Cleaning Utility minimizes the chance of a computer freeze or crash caused by various file issues.
Defragment
Use PC Cleaning Utility to defragment a computer's registry, as over time a computer's registry becomes fragmented when files are constantly deleted causing performance to decline.
Clean Registry Issues
PC Cleaning Utility's Advanced Registry Detection Technology detects and removes or repairs registry files issues as well as fixes wrong system configurations.
Prevent Crashes and Freezes
PC Cleaning Utility fixes corrupt registry entries, operating system hidden issues, corrupt system files, missing dlls and more so you do not experience random computer crashes and freezes.
Defragmenters
After extended use, a computer's registry becomes fragmented as numerous files are downloaded and deleted. Due to the way files are saved on a hard drive, repeated file deletion causes a computer to eventually run at a slower pace.
Start-up Manager
Utilize PC Cleaning Utility's start-up manager to easily select which files to open during your computer's startup process. The start-up manager makes this process easy by allowing you to simply click which programs are to be started during a computer's boot up.
Select Which Areas to Scan
With this settings option you can choose which areas on your computer to scan and clean. Choose from virtual devices, libraries, installations strings, junk files, temporary files, system software, history and start menu, and more
Easy Install
Scheduled Automatic Scans
The automatic scan option allows users to choose what day(s) to automatically scan and clean your computer. Users can schedule a scan everyday, once a week, and the time of day.
https://shieldapps.com/
rge6r.PC.Cleaning.Utility.Pro.3.8.7.Premium.Multilingual.Portable.rar.html
